[WANTED] Carter fuel line fitting inlet for 67 Carter 4299S
31pickemup
Ohio
Rating - 50%
1   1   0
Hey guys my Carter 4299S has the wrong Fuel line fitting inlet. It has a male nipple on it instead of the original female inlet. Anybody have one they want to part with?
A good local hardware store should have one. All you need is a 5/8 18 male to 5/16 female flare.
We'll I want a factory piece. I'm using original reproduction lines. I didn't want two pieces when I can use the correct one. But I appreciate the input.
I think the aftermarket male nipple unscrews from carb and line/fitting will thread into carb. Make sure there is a screen inside carb.
Post pics
No it won't the hole is too big. It has to have the special adaptor. It looks like this.
