Frank Negron
New Member
Hi. This question relates to a 750 Street Demon in particular but I believe it's for all carbs based on Carters probably even all carbs in general. It's so basic I feel a little foolish asking it.
At what point does the pump nozzle squirt fuel when working correctly?
The accelerator pump rod is set to spec and moves the pump rod/plunger immediately with any movement of the throttle. However the nozzle doesn't deliver fuel right away. It takes a good 1/8" downward movement of the pump rod/plunger before any fuel is squirted.
I always took for granted that there should be no delay and that there is a direct correlation. Hit the gas pedal and the accelerator pump squirts fuel.Thanks
