.........carter thermoquads........
I have a '74 440 that I believe came with a Carter spreadbore. I will double check in the a.m. In the meantime would you have the correct one for this app?
What sort of HP numbers do you have? Any of these: 9800S, 9801S, 9810S, 9811S?
I need a phenolic body for my Original 74 Duster 4 BBL. It's # 6452S. Body is O-2381A. I'd buy the whole carb if need be or another with that body #. Thanks.
You should post the carbs numbers. It'll save time and bologna.
