cast 833 over drive 74 dart sport 340
arfire
Active Member
quitman
Need info on who is running one and what
Rear gears are used ,a little info on how you like it ,
I had one behind a tired 318 with 2 something gears worked pretty good then I installed a mild 360 with 3:55 gears didn't like it at all to low of 1st gear a big drop to second took the 833 OD out and installed a regular 833 works much better with the new combination if your determined to use the 833 OD IMO use high 2's or possible 3:23 gears you need to get the momentum going due to the big drop into 2nd
^^Ditto for me, The splits suck for a hi-revver
But Pretty good for a stock engine.The 3.55 x 3.09= 10.97 is a nice starter gear. The 3.55 x .73/.71 od =2.56 is a good gear for a STOCK engine.
3.91s totally suck with 28 inch tires or smaller.
Great ratios fo a slanty, or stock teener.
I put one behind a HO 360. Bad idea for me.
AJ's Quest for the Funnest Street 360-4spd Combo;short version
I'm running one behind a 440 in short bed truck.
I don't know what the rear gear is but I'm certain it's the stock gear from the original 6 cyl truck.
I do spend a LOT of time in second.
245 60 15 tires IIRC.
