"Cat Whiskers..."
nodemon
St.Louis
How are the cat whiskers removed / installed..?
72 Demon
Thanks,
John
If yours are the same as mine (68), then there are clips built into the back of the strips that slip into a slot in the door. They form a "U" shape, so method for removal is a lifting and pulling away motion to remove it from the slot.
When installing the new ones DO NOT USE a steel hammer to help guide them in. Use rubber ,plastic something soft.
