CB Performance Black Box review - PLEASE, DO NOT BUY THIS STUPID WORTHLESS GIMMICK.
Robert M.
New Member
Oakland, CA
I tried the CB Performance Black Box 2013 because it is a good idea. However, it does not work right and You will never be able to get it to work well. I guarantee it. I am writing this because after spending about 40 or more hours of time and close to $500 trying to make it work, its just not a good product.
I needed to write this to offset some small amount of my loss trying to use the product by ensuring my Mopar brethren keeps these Dollars and hours in the bank to be used for something worthwhile.
Main problem is that the Black box for some reason cannot read the RPM's smoothly. There is a readout on the laptop. Above like 1800 or 1900 rpms the signal becomes erratic causing the rpms to jump from like anywhere above 2,000 to like 18,000 due to noise. This changes the rpm dependant timing electrically and causes all kinds of backfire and terrible engine performance. It worked better for the first 3 or 4 miles, but then never worked good again even with the addition of a MSD Magnetic signal Stabilizer.
So if You have a Mopar and You are having trouble with the ignition and want to put in a solid system, this is what I would recommend:
#1: Jeg's has an American made ECU called the HiREV 7500 for about $100 delivered. On the Jegs website, there are about 3 or 4 little tests you can do with a multimeter to make sure the voltages are correct. Do those.
(For example, the instructions said I needed 7-9 volts between the coil + and - when key is in Run position.I only had 5.30 volts, so I added a second ballast resistor in parallel with the existing ballast resistor stop resistor, and it brought the coil to about 7.5 volts. Ran extremely well.
#2: Coil: Get a stock replacement or just check your stock or aftermarket unit to make sure it has the resistance specified in the ok instructions with the Jegs HIREV 7500 ECU. I ended up using my stock coil because the MSD blaster 2 was out of the specified range of resistance between the + and - of the coil.
#3: if you have a electronic ignition distributor of the OEM type, you can try it. Make sure the gap is between about 0.008inch and 0.0010inch.
It might take 10 tries or more to get the reluctor gap just right. You might try tightening down the screw with a 0.016inch feeler gauge in the gap, then take that feeler gauge out and measure where the gap really settled.
It needs to really settle at 0.008 to 0.0010.
#4: You should order one of the Limiter Disks you've heard of. Put it to like 18 and then put your initial timing to 18 and try that. (This is while there is no vacuum advance connected)
Get the Car running good at like 14-18 initial with like 16 or 18 from the mechanical advance in the distributor for a total of around 34.
I finally got my car to run very well at 18 initial and 18 mechanical. And You should get your car to run real well in this manner as well.
Then, you can include the vacuum canister in the loop if you wish. There is no easier way to do it that this, just like all the old timers on FABO say.
If you can't do that, then You either need annewn$100 distributor from your local parts store, a new HiREV ECU from Jegs, a new stock ignition coil, or your ballast resistor is burned out, or you are not getting 12 volts to the Ignition Coil +, or your ECU is not connected well to the - terminal of the battery.
It's not a bad system. (Beware of damaging the vacuum advance mechanism in the distributor which is a little flimsy). I'm just saying you don't need any other ignition system to get your Mopar engine to run great. If it isn't running great, something is wrong with one of these basic 4 or 5 components, all of which can be readily purchased new without breaking the bank.
In no case should you try to implement a CB performance Black box 2013. Even if you are an electronics wizard and think you can make it work good, ita just not a reliable device and in fact you probably won't be able to get it to work well enough to drive 10 miles or above 2500rpms. Even if You want to be the one that does it right and gets that sick tuning map capability for just $200- it's a trick. If you simply must invest $200 in your Mopar ignition right now, get a new OEM Electronic Distributor and a Jeg's HIREV 7500 ECU.
Sincerely,
Bob
Never heard of the Black Box aside from airplanes. I've always used either the stock setups, electronic, or MSD.
Currently MSD everything sans wires which are Taylor...and use NGK plugs.
Never heard of this brand/ device.
When I read the title, I thought you were referring to illegal Citizen's Band radio power amplifiers. Since they are illegal, there is no reason for any, uh, "manufacturer" to adhere to any decent standards, either reliability, performance, or signal purity, and for that matter, truth in power output ratings.
On a side note, as a guy who's been in / out and on the fringes of electronics most of my life, I've never heard ANYBODY outside of the CB crown refer to a transistor as a "pill"
This guy?
Wow, these went up in price. Like everything else.
This guy?
Wow, blue box is made in USA. I would like to see what is under the transistor cover. (or what isn't there)
This guy?
Weren't they like 39.99 before?
If you have a magnetic pick-up, I suppose that you know that they are directional. If the polarity is reversed, they sorta work just as you say.
If it was me, I would reverse the polarity of the pick-up, just for kicks and reset the base-timing. Then try again. I think you will then be able to open up the reluctor gap back to something more sane.
You cannot hurt the amp, by reversing the pick-up polarity.
Best of luck
I happen to think that anything outside of the style of the factory Chrysler electronic ignition is a gimmick, so you don't need to worry about me wasting my money.
Think the Multiple Strike Discharge is kinda cool. I remember a display I seen (the one it was actually wired up and working) back around 1990, you could spin the distributor, and just watch all the different arcs coming off the plug ( it was pretty cool) but I don't run one, personally. I'm kind of from the less is more mindset. More reliable, less stuff to go wrong. Like one of our members says on his profile "the parts that you don't add, don't give you any problems"
Hi. It's been a couple of years since the original post, but I thought I should reply. I own a Barracuda...but the car I'm going to refer to is my '63 Lincoln with a 430 MEL engine.
I installed a CB Perf Black Box in/on the Lincoln because I got tired searching for "the perfect springs". Nobody near me has a Sun machine. Nobody sells "sets"...so I was stuck trying to convince random springs to work for me. I got tired of using the engine itself as a re-curve machine. For a $200, I thought I'd give the Box a try.
It is excellent. I run it with the original distributor and a Pertronix 2 (good condensers and points are getting hard to come by, too). I was able to set the timing using the 21x21 table in their software (that looks like it's from 1996). I can adjust the advance quickly and easily using a Windows laptop. It's been nothing but good for a year and a half now.
I can start the engine at 10 degrees and have it immediately advance to 24 degrees for idle...so the starter doesn't complain. I can set the "all in" advance to whatever rpm I want. I go for a drive and give it the beans, and if there's a ping, I simply back the advance off a couple of degrees on my laptop. It takes 10 seconds.
That being said...the Lincoln engine never exceeds 3800 rpm, so I can't comment on higher rpm operation. I didn't install it in a high performance situation. It was more of a convenience thing.
My Barracuda is mint and stock. No black box on it. Points with a limiter plate.
Thanks for reading.
