Carter carb; buy the kit. Before putting it on, ritchen secondary jets 3 or 4.
Now when you start that eye-burning thing;put a vacuum gauge on it, adjust screws for highest vacuum, keep turning down the idle until rpm is ok.
Read the blackened plugs. Now swap primary rods to leaner idle; same wot upper shaft. Go run it hard, without opening the secs; re-read plugs. Adjust idle again with gauge.
Keep playing with primary, until eyes don't water, plugs look good. Usually it can be done with only the rods, sometimes a jet change, then start all over.
The jetting in the sec doesn't affect the drivability. If you want to check them, make a full bore; you can drive 1 mile back to the house, and still read the plugs for that.
The springs; Turn the covers 1/2 way off, so you can see the rods move. Idle- all the way up, goose it-instant down. Acel rod- cloest to carb body.
Infinite tuning on them.
