Champion Radiator Transmission Line Size
srduster340
Decatur,Ga.
Anybody out there with a new Champion radiator with a manual trans? I need to plug the tranny holes but I can't figure out what size plug I need. I tried to use my tap set to figure it out but no luck. Any ideas?
Don't have that radiator, but all I have seen use pipe threads, usually 1/4" NPT as I recall. Plugging is just keep dirt out. It wouldn't leak water if left open or plugged w/ paper.
I just got a champion radiator and I do believe that is correct 1/4" npt. It did come with a nipple you could use for a size comparison or at least mine did.
The Champion radiator in my son's Dart uses 5/16 inverted flare fittings. We had to have a friend machine a custom pair of 5/16 flare to 5/16 inverted flare adapters to attach the trans cooler lines. Challengergary verified that the fittings are in fact 5/16 inverted flare. If you're just blocking them off, you can get the 5/16 inverted flare plugs at any hardware store.
I might need a pair or 2 of those in the future. What was the price for them?
My friend did them for nothing....took him like 30 minutes to mod two 5/16 flare unions. You could probably do the same mod in a drill press and get satisfactory results. If there is enough demand for this type of fitting, I could see what it might cost to have a run of a dozen or two machined up for sale.
Here's a photo of the machined fittings:
I talked to my friend the machinist and he agreed to machine up 20 of these fittings for me. If anyone is interested, send me a pm and when they are finished I will let you know. Price looks like $17 per pair shipped. Additional pairs will be $12 shipped by combining shipping.
