Cruisingram
I want to change out the oil pan, took a lava rock, do I have to remove the motor to do this? Looks pretty tight up front by the K member!
You should be on a pit crew, Rusty- Geez, it takes me 30 minutes just to get up off the creeper!I guess. I just resealed Vixen's pan recently and I pulled engine and transmission. Out in about 30 minutes with hand tools. I mean seriously. Why work in a cramped space up the farkkin side down and risk a leak? Get it out, put it in the stand flip it over so you can SEE it and do it right. Or don't. It's up to you.
Well it is a 64 base model so it has zero accessories.You should be on a pit crew, Rusty- Geez, it takes me 30 minutes just to get up off the creeper!![]()
Takes me 30 minutes to THINK abont finding the creeper.....Takes me 30 min to find the creeper......
It says slant 6 in two different places in two different headers.You did not mention engine type or model year, so.........
I did this from underneath with the engine in place on a 1970 with a small block a couple years ago.
I did have to disconnect the arm on the steering box and the idler arm at the K-member which allowed me to swing the crossover bar out of the way for clearance.
Ok, ok. 30 minutes AFTER the radiator is drained. Fair enough? lolTakes me 30 minutes to THINK abont finding the creeper.....
Great opportunity for you to look it over and freshen up as needed!Just got into my new shop, still trying to find my *** with both hands. I figured I would pull it, just thought to myself and said "geez, what if I don't need to pull it, better check it out"- I started on it yesterday and got a lot pulled. It sat for so long, everytime I pull off a bolt I am afraid of stripping, breaking or messing something up that will take me a couple weeks to get ordered and in. Going to hammer away on it Wednesday and see if I can knock it out in one day. Painted the new-ish- oil pan yesterday, have valve cover and oil pan gaskets in, so goign to try to button it up real tight for a new leak swap when it's back in.
Sounds like a great project for you! Onward!Well, part of it is that i am slowing down the rush to put the 225 2bl motor in right now, I am going to run the 170 and take a little more time doing good work on the 225. I am going to do things like port match the heads etc. I have lots of parts I need to detail and make ready.
I can get my slant out in 30 minutes flat, I have done it a few times but I might be cheating because my 68 dart has NO a/c, NO power steering and is a manual transmission.
Usually the hardest part is the exhaust bolts because sometimes they are a bit corroded and don't want to come apart smoothly. Other than that, a slant is so simple to remove that even a girl can do it..... In 30 minutes or less
I think I could have had this engine out in an hour or so if not for all the corroded bolts. Sigh.
I can just hear that conversation....."Hello, insurance company? I just lost my house in a lava flow......hello? hello?"Trouble in paradise. I have a Barracuda Buddy who lives in Hawaii during the winter (2nd gen convertible) and he complains about corrosion too. He lost his house in a lava flow. He also has Hemi and 440 powered cudas here when he summers in Ohio and those corrode during the winter in an unheated garage.
Send me a plane ticket and I'd be happy to help out. Should be done by March or so. (wink)
Funny my water well collapsed, and I called homeowners was not surprised when they said it was not covered. A friend of mine went ballistic, said "thats bullshit call a public adjuster" I know one personally texted him in front of the gay and the adjuster said "no damage? not covered" anyway still waiting ion the driller to come out. i had the estimate and the money quicker than anything. The driller was like "15 grand" I said lets do it, I think he wasn't expecting that ...I can just hear that conversation....."Hello, insurance company? I just lost my house in a lava flow......hello? hello?"
