I have 70 dart that i rewired using a R Francis kit. I also relocated the battery to the trunk. Everything works fine but I can't get the alternator to charge the battery. I took the alternator out and had it tested and it was okay. I reinstalled the alternator, pulled a field wire and connected it to ground, started the car and and the volt gauge finally showed a charge over 12.4. (Thanks to 67dart273 for the test from another post). I have tried (3) different vr's, grounded the vr's with a jumper wire as well as the standard ground and still can net get more than 12.4 volts. Any suggestions are appreciated!
