Charging issue
Kegan B
IN
Alright, I'm not the best when it comes to electrical stuff.
1974 Duster (/6 with stock 60amp alternator), the car sat for about 10 years then I tore it apart to paint it. Battery is at 12.29 volts but I can only get about 9.42 volts at the stud on the alternator and on the blue wire at the voltage regulator. Fusible link is intact, I cleaned the bulkhead connector (to start with I had 0 volts). What am I missing? A broken wire or bad connection someplace? Thanks.
12.4 Volts at the battery with nothing on is a bit low. Put it on slow charge and see if it will come up.
9.4 at the alternator shows a voltage drop. What was on when the measurement was taken? What did the ammeter show?
This is what you need to know to evaluate a voltage drop.
Voltage only drops when electrons move, or try to move though resistance.
It'll come up, it's low from me fighting with this issue most of yesterday (it's on a slow charge right now so I can put it back in my other car). Key was on but radio and lights are off, it's the same with it running or just key on. Ammeter stays to the left side, I'm going to guess there is corrosion someplace.
Key was on. Ok that's a help. And the alternator is not providing power, so that's another clue. And hte engine starts and runs so that's all helpful info.
How far to the left was the ammeter? Halfway left? Just a little?
One dumb question. How did you measure voltage at the regulator's blue wire? Did you remove the connector and then put it back on?
It stays slightly to the left, it never fully shows discharge. I back probed the connector at the voltage regulator.
