Nelson7604
Active Member
Ok...Well here's the skinny...I got a brand new alternator, but I ended up breaking one of the brushes. I got a new set of brushes for it and when I fired it up again, one of the field wires nearly melted off along with the new brush.
I diagnosed that as my impatience when I noticed I put the two field wires on backwards (if that makes a difference; I followed my wiring diagram as I'm not familiar with how alternators work). I then tore the harness apart and replaced the damaged wire(and new brush), fired it back up and no charge.
I fired it up again after I got headers, didn't pay attention and melted through the ignition wiring harness with the headers! I cut the bad wire out and spliced every wire again with solid connections (Still no charge).
After about a couple weeks, it finally started to charge out of the blue. Thinking it might have been a loose/bad connection that I fixed somewhere along the line I kept an eye on it with a voltage meter (getting around 15v at idle). Sweet! all taken care of!
NOT!! Fired it up to move around in driveway and alternator was smoking like crazy and same field wire was getting hot. I shut it all down, disconnected wire and battery and there it sits...
Am I missing anything? Other than patience... Should I get another alternator or did something short out during all of my stupidity that I need to replace?
Anything will help at this point. Thanks in advance.
