Between myself and a few others, we haven't been able to figure out why my car isn't charging. New battery, alternator, voltage regulator. Had them tested (i have bad luck getting a good alternator the first time, this was my 3rd!), working fine. Triple checked my wiring on the dual field alt, looks ok. Checked grounds. Repeatedly.
The battery isn't charging when the car runs, and the car is running off the battery. I've replaced the battery wire from the alternator after the old one shorted out. If I remove the wire from where it goes into the bulkhead (which eventually leads to the ammeter) the car will die instantly. So I'm thinking the wire coming back through the bulkhead off the ammeter and to the starter relay may not be connected somewhere. Because the wiring from that relay to the battery checks out.
I've also tried running an extra wire directly from the alternator straight to the battery to see if it'd charge but it still doesn't. I'm sort of at a loss here.
