Clamps for connecting parking brake cables?
Discussion in 'Brakes for your Classic Mopar' started by MRGTX, Mar 23, 2018.
  1. MRGTX
    MRGTX Well-Known Member
    1,447
    454
    Sep 24, 2007
    CT, USA
    Local Time:
    10:34 AM
    Is there hardware for permanently connecting parking brake cables?
    Lokar has these cool block clamps tht are useful for making linkage from scratch...and these blocks with set screws are sort of what I have in mind but I’d want the cables to be end to end so the vector of the pull was properly in line ...maybe I’m an idiot (almost certainly) but I’m not finding what I need.
    There has to be some standard way of doing this, no?
    Any suggestions?
  2. Dana67Dart
    Dana67Dart Most undignified way to get to Colorado!
    1,156
    381
    Jul 16, 2017
    Northern Colorado
    Local Time:
    9:34 AM
    google "wire rope". I looked and there are many joining methods. watch that it is not for electrical. Did not find exactly what you describe ( I have seen what you describe)
    What is your application?
    • Thanks! Thanks! x 1
    • Dana67Dart
      1,156
      381
      Jul 16, 2017
      Northern Colorado
      Local Time:
      9:34 AM
    • TrailBeast
      TrailBeast Slightly Twisted Member
      18,566
      4706
      Mar 11, 2011
      Arizona
      View My Photos
      Local Time:
      8:34 AM
      Why not just use a basic cable clamp?
    • MRGTX
      1,447
      454
      Sep 24, 2007
      CT, USA
      Local Time:
      10:34 AM
      So...this is a good question. Is this not considered safe for some reason?
    • 72bluNblu
      72bluNblu FABO Gold Member FABO Gold Member
      8,754
      2685
      Nov 28, 2008
      NorCal
      Local Time:
      8:34 AM
      • Agree Agree x 1
      • TrailBeast
        18,566
        4706
        Mar 11, 2011
        Arizona
        View My Photos
        Local Time:
        8:34 AM
        I know I would trust them more than an allen screw clamp, and it would keep the cables inline with each other.
        • AJ/FormS
          AJ/FormS 367 FormS clone 3.09-1.92-1.40-1.09-.78od 3.55s
          13,714
          3312
          Jan 19, 2014
          South-Central Manitoba,Canada, 900ftelevation
          View My Photos
          Local Time:
          10:34 AM
          It's a parking brake;mine had to be working to pass Manitoba safety, in 1999.
          I don't recall ever using it since.
          Clamps would not pass safety up here, even tho it was working 100%; it's a government thing. If I passed it, I could be liable to a $7000 fine, and my employer could be subject to double that......even tho it's a stinking parking brake.....that hardly anyone ever uses.
          By now, mine's probably seized again.....
          Kindof like my horn; it had to be working to pass safety. It died again shortly afterwards, and I have never needed it in all the intervening time. I haven't had a working horn since before 1981. I got a big box full of horns. They used to get me into a lotta trouble. As I got older......and flabbier,I figured it was better not to have one.
        • Dana67Dart
          1,156
          381
          Jul 16, 2017
          Northern Colorado
          Local Time:
          9:34 AM
          What is the application?
          What's the issue?
          Can't find OE replacements?
        • moparmandan
          moparmandan FABO Gold Member FABO Gold Member
          819
          392
          Jun 28, 2017
          Central FL
          View My Photos
          Local Time:
          11:34 AM
          Lot's of options. Crimp a swage on and get creative. Here's what I did: 20180311_180403.jpg
        • MRGTX
          1,447
          454
          Sep 24, 2007
          CT, USA
          Local Time:
          10:34 AM
          Thanks for all of the input here, guys!
          The deal is that the new disks with internal parking brake (Ford Exploder pieces) don’t have the ball ends on the cables. They’ll need to be cut to length...so I’m looking for the easiest/reliable way to connect the stock cables to the new ones.
          What’s up with the price on these!?
        • MRGTX
          1,447
          454
          Sep 24, 2007
          CT, USA
          Local Time:
          10:34 AM
          Do you guys really not use your parking brakes? The only time I deliberately don’t used them is when the car will be sitting for long periods...On perfectly flat surfaces.
          It’s just a good habit, IMO.
        • moparmandan
          819
          392
          Jun 28, 2017
          Central FL
          View My Photos
          Local Time:
          11:34 AM
          That's what I did. Look closely. Ball on one end swage on the other. Check out the 8.8 swap page.
          • 72bluNblu
            8,754
            2685
            Nov 28, 2008
            NorCal
            Local Time:
            8:34 AM
            How do they make the connection on a Ford Explorer?
            Seems like that would be the thing to figure out, if it’s good enough for Ford it should work fine for you.
            Either that or you’ll need to have a custom cable made. Although honestly that shouldn’t be all that expensive, and it will look a lot cleaner.
            I always use mine, and all of mine work. They’re super simple, if they don’t work it’s an easy fix no matter what the problem is. At least with stock parts and drum brakes anyway.
            With my cars if the emergency brake isn’t set the wheels are chocked. Everything that I drive has a working emergency brake, the projects are mostly chocked either because of the time they’re sitting or incomplete brake systems. But even on those I like to have the e-brake working because it makes moving them around a lot less exciting since not all of them have fully working brake systems.
            And on that note- there’s a reason they used to be called emergency brakes. I don’t like that new cars call them a parking brake, although I guess if they’re electronically controlled they probably run through a computer that will keep them from being used in an emergency anyway. Or run off of the same hydraulic system which makes them useless in a hydraulic failure. Not everything from “back in the day” was the best way to do it, that’s for sure, but some things really were done a certain way for a reason.
          • moparmandan
            819
            392
            Jun 28, 2017
            Central FL
            View My Photos
            Local Time:
            11:34 AM
            Post #10. Mopar ball in one end ford swage in the other.
          • MRGTX
            1,447
            454
            Sep 24, 2007
            CT, USA
            Local Time:
            10:34 AM
            Thanks again, guys.
            Yep. I'm going to learn how to swage. It doesn't seem too difficult but without the tool, it's murder on your teeth. :)
          • moparmandan
            819
            392
            Jun 28, 2017
            Central FL
            View My Photos
            Local Time:
            11:34 AM
            Yes, unfortunately, the crimpers to crimp the swedge's is a little high for occasional use. Maybe you could weld them on? When I was considering my options on my project someone recommended a garage door company that could crimp them on. Good luck with your project.
          • MRGTX
            1,447
            454
            Sep 24, 2007
            CT, USA
            Local Time:
            10:34 AM
            So I am going to pick up a swage tool and do this properly but in the mean time, I am finding that standard/small cable clamps seem to be up o the task (at least for a temporary fix until my tool budget recovers). Yes, wheel-curbing, wheel chocks will be used rigorously in the meantime as I will never fully trust these.
            One more quick question; when routing the cables, it seems like the cable wants to cross right under the front u-joint...which seems pretty obviously wrong. Where does your cable cross the driveline?
            I'm SO close to being ready to roll...I just consistently get hung up on these little details.
          • adriver
            adriver Blazing Apostle
            5,536
            2182
            Jun 1, 2007
            Where the red fern grows
            Local Time:
            11:34 AM
            If you have a hydraulic press (they are cheap and VERY useful), you can cut nuts in half and make a dies to swage things.
            • Like Like x 1
