Classic Instruments Gauge Cluster Install - 71 Demon
ACME SS
Emmett, Idaho
A few weeks ago I was installing Classic Auto Air, air conditioning in my car and in a matter of 20 minutes I had to discard the lower dash mounted oil pressure gauge and then the tachometer was next. All that was left was the original cluster, of which only the speedometer "worked" although it had the wrong gear. The fuel gauge posed as functional but was less than accurate.
It was time to pull the trigger and do something. I chose Classic Instruments because they provide a new dash panel. The installation was simple, just need to get a schematic and splice into the correct wires. Their instructions could be improved with a schematic showing how to wire up the gauges but I have done that on a few cars in the past so it wasn't difficult. Essentially, you daisy chain the grounds from one gauge to another, as well as the dash light and 12V power wires. All that can be accomplished on the bench. I then installed my own wires to each gauge, approximately 18" in length, enough so I could do all the splices with the panel laying on the steering column with padding under it. Before installing the dash, I zip tied the wires into a loom (not pictured) to relieve any stress from the crimp connections. I'm not a huge fan of crimps but I read an article by Ron Francis wiring years ago that said soldered connections can fail at the solder edge when bent, and this makes sense. So with that in mind, I zip tie such that no bending can take place at the crimp connectors.
I used plasti-dip on the chrome knobs. I did 2 dips and it seems to be OK. We will see how it holds up.
The speedometer is super simple. You replace the cable with a pulse generator at the transmission and plug in the harness provided, which replaces the cable. they provide 3 options to program it. I always choose to use my hiking GPS which is accurate to a few feet of a mile. You simply tell it what a mile is and it then knows how may pulses to a mile. Tach is even easier.
Jerry
I have been looking into that gauge cluster frame for my Scamp. I have the gauges already, and would just want the piece without the gauges.
A Nascar trick is to have each guage rotated so that the needle is pointing streight up when it is reading normal.
Looks odd but is very functional.
You know, I thought of that when I first drove it. The Tach is really odd on this in that it rotates clockwise but zero is at 5 oclock. It just looks wrong. If they hadn't wrote RPM in the middle of it, I would do it.
It's that way so that shift-rpm is near 12 o'clock, which is really the only rpm of any meaningful relevance, lol.
When I did not yet have a tach, I put lil stickers on my speedo, at the appropriate places. But for a track-day, I wanted a shift-light and a rev-limiter, so I bought a relatively cheap tach with both of those in it . But honestly, as a streeter, I never look at it anymore; the 367 spins the rubber to well past the speed-limit and Second with 3.55s is good to 80Plus mph. So, she don't much care where the 1-2 shift occurs, lol.
Very nice dash, btw.
The little stickers reminds me of when I took my dads 66 Dart to the DMV for my drivers test when I was 16. I passed the test first time but the examiner says "what are all those little pieces of electrical tape on the windshield for? I had to explain that my dad would put them where the sun reflected off the cracks in the windshield so it wouldn't blind him. I went home with my temporary license and a fix-it ticket for dad!
I'm more impressed with the great to the point explanation AND photos. Rare commodity. Looks great as is by the way. - Thanx
Looks really good- thanks for the info! Your neighbor in Meridian....
