[WANTED] Clips and screws that hold heater cables on controls
340doc
Dunnellon Fl
When we bought our 70 Dart the heater box was missing. Got a box from a member here and getting ready to put it in. Jammed my head under the dash and the clips are missing where the cables attach to the heater controls. if anyone has all the clips and screws that attach the cables for a non AC car let me know. Thanks
I don't have a pic of the ones I need but by the way they attach leads me to believe they are the same as the ones that hold the cables on the heater box. I can take a pic of those after work. Thanks for your reply.
Yes those clamps are the same used both ends. There isn't a screw though. There is a hole where a screw could be placed should the clamp tension fail in some way. ( That's probably more likely to happen where they clamp onto the hearer case ). I've sold off the extra clamps I had here. Good luck
Yes those clamps are the same used both ends. There isn't a screw though. There is a hole where a screw could be placed should the clamp tension fail in some manner. I've sold off the extra clamps I had here. Good luck
Thanks for the info RedFish, I did see a screw hole.
I know I have a few of the clip on rectangular types. Do the pic of it and post it.
I have these two, prob the one on the left is the one you want. $5 shipped?
right side is the one the screws go into to hold the armrest to the door.
The one on the left looks right from memory, you just have one?
The Chrysler part number for this clip is 6015143. Google the part number and you can find repos (R/T Specialites) and NOS ones. Priced usually around $5.00 each.
I have a couple of spare NOS ones to sell for $5 each with shipping included. How many do you need?
I'm surprised nobody has come through with these for you, so send me your address and I'll send you a few!! I believe I have a few of the screws they use as well!!
