cloudy taillights
RTSduster
Active Member
Anyone have a solution to restoring a new look to dull plastic tail light lenses? Appreciate any suggestions.
Rubbing compound and a lot of elbow grease with a soft cloth will get most of it out.
Some red rear lenses get dark for sure. Take the fixture apart and wash the inside and upgrade the reflective bowl helps.
If its 67 or 69 Barracuda, Same service applies plus you can add bulb sockets to those fixtures.
autozone and advance auto have lens polishing kits for plastic lenses in the auto body section. They seem to work fine for me and the luster is very nice
You can use heat but you have to be VERY careful. I would only suggest giving a small propane torch a try as a last resort if nothing else works.
