And when the capacitor is close to coil, it does the best job. A filter at or in the radio is too late for radiated EMF, it helps only with conducted noise on the power entry. The radiated EMF happens between the coil, and the wiring back to the source and ground, becomes an antenna. The radio picks up the noise via the antenna. The spark signal is rich in frequencies, so there are many frequencies that are in tune with the wiring length back to ground. The capacitor greatly shortens the length to a few inches, reducing the noise spectrum. Harmonics decay with the reciprocal of the odd harmonic number. The capacitor also results some in improved spark energy to plug, using the energy that would otherwise be radiated as EMI.
