If the key is in the run position, the points are closed and you are not cranking the engine current is flowing through the ballast resistor to the positive side of the coil, through the coil, out the negative side of the coil to the points, through the closed points to ground. The ballast resistor is getting hot because effectively you have it connected across the battery. The ballast resistor is there to protect the coil from burning up. When cranking the car the ballast resistor is not used and the e tire battery voltage is applied to the positive side of the coil so that you'll get a hotter spark for cold starts. When the key is released to the run position the ballast resistor is in circuit limiting the voltage to the coil.
So what I'm saying is that the ballast resistor will get hot if the ignition is left on and the points are closed THIS IS NORMAL..
Hope this helps
QUOTE=barbee6043;1970220177]sorry about my ramblin.
i stated i beleive current runnin thru car ( key on), new coil, comdensor, ballast, coil, i relize any could be bad through new. just sent to town and got another New coil. No resistor, . i'll save my $ and get tack-dwell tester and multimeter,
installed new coil, hit remote ( keu on), got intermittant spark at test light at neg coil wire, slight spark out big coil wire, noth it plug wire. THEN---- nothin at neg coil wire, power to ballast gone later comes back , heat at back of ballast. jumper from bat to pos coil gives nothin at eng coil.
Questions: do i have a short somewhere? did i fry the coil just that quick? is the resistor necessary?? remember, i said the fusible link was burned into when i got it
my neighbor the shade tree mecanic has these testers and wants $40/ hr. $40 will have to buy livestock feed and hotdogs for me the next 2 weeks!?? LOL no really. i will be lookin for bargain on some used testers!!! i no i need them. thanks again for any input.[/QUOTE]
