Ain't that the truth?
Can’t fix retardation, once it’s set in, it’s for life….
Check your PMs again, tardamous.
Boy that's a fact. It just puts unneeded stress on everything before the plug. With modern low resistance wires there's just no need for it.They should have called it High efficiency Ignition, it’s of that era where they were making **** for the new smog rules being pushed in the masses of street cars.
We run 6AL digital boxes on the 4cyl to 10,000+ RPM in the power band of 6-10 k RPM the whole 20-30 minutes per session, For 15-20 hours before a rebuild. We might have one box fail every 2 years. Not saying that are the end all be all, but for the price point way better than the HEI BS.
The HEI is not gods gift to ignition. And why the f*** would you want to run .080 gap? That’s just a waste of energy trying to fire the spark that far with a higher chance of not having the spark jump.
Turk,
You are getting worse...
Letting 'hate' get in the way of reason.
And now for the fourth time: what does the 3 amps refer to in a '3 amp magneto '. You say you KNOW. Well, tell us! does it mean the mag generates 3 amps of current in the primary winding? There is 3 amps in the spark current?
Fact is you haven't got a clue....& haven't got a clue about many other things. When your BS.....is shown to be BS, you resort to name calling & denigration. A real hero...
Oh, the ignorance....
HEI, like every other device, on the planet has it's limits. Being inductive ign, it runs out of time to saturate the coil as rpms & the number of cyls increase. CD ign such as the MSD 6, 7 boxes etc do not have this limitation & can go to higher rpms. Why do you want 0.080" plug gaps? That rough idle from that big cam is actualy caused by the engine misfiring. Anything that can reduce that such as a bigger plug gap &/or hotter spark will be a bonus.
Low resistance wires does not automatically equate to more power, because 'the wires' are just one of many series resistances in the high tension cct.
And here is another 600+ HP engine using HEI ...& it s not built by D. Vizard, it was built by Dart Machinery....
From post #8
E-Coil fired plug gapped at .035 ths.
Burning clean, runs fine.
_________
Most people coming to this thread will come in and read down to post #8.
Resulting in > "Now that's a great simple ignition where the e-coil runs cool to the touch".
Addressing the question the OP was asking about the operating temps of coils.
This is when the viewership for this thread really took off. Going from 120 views, to 500, to 1000, to 2000 views all in short order.
Later on long winded postings are just people showing up late to the game, and they get ignored.
As proof now as the viewership is stalled out at 2000 views, as people are getting bored with it.
The numbers tell the story.
Hi Folks
One of those things that I have never really thought about.........
The facts......SBM with oem electronic ignition using a Hi Rev 7000 ECU.
1.2 ohm accel coil (oem type) with .7 ohm ballast.
While running for a while, I touched the body of the coil while adjusting timing and it was so hot that I couldn't keep my hand on it. Is this normal, or is this thing running abnormally hot.
Thanks FABO
This is the coil I bought. Specs say universal with 1.4 ohm primary (I measured 1.2 with an accurate ohm meter). I bought it because the FSM listed 1.4 ohm for my vehicle. It is NOS from the 90's. Just reading the specs now, it says "points style". Would that make a difference If running an OEM electronic system?
When you shake it - Can you still hear the oil - Full ?
Are you having any RPM issues , higher RPMs say above 5,000/5,500
Starting issues when hot ?
Typically at idle your oil filled coil will get hotter because of the longer duration dwell time at idle versus higher RPMS cruising down the streetI just stumbled on to it messing with the car in the garage. Idle, fast idle and 2500 while I was getting my fluids in order and the timing nailed down.......and centring the PS gear.
Looking at that plug only says the idle A/F ratio is acceptable. And that the total timing is close ASSUMING that you made a hard, full throttle hit before you pulled the plug.
If you didn’t do that then you have way too much initial.
What we can’t see is WOT A/F ratio and spark mark.
The former shows how well your WOT carb tuning is and the latter shows how good (or poor) your ignition system is.
Does that plug have spark mark?
What you have done with your post is add more confusion about timing, jetting and plug reading. Nothing more than that.
BTW I can get plugs to read like that with points. That’s my point. You have nothing special and you don’t need anything special because you build nothing special.
Cus he learned it all from magazine martial writers, which are just as bad as teachers it not worst. If you can’t do, teach….Plagiarize much?
Why can’t you articulate things in your own words? It’s ok to post things other people do but a you do is copy what they say.
You should be ashamed and embarrassed.
I doubt he even have a Box tester and a test plug, let alone a distributor machine. you don’t watch the spark arch, you hear it, that test plug is the largest gap you’ll ever has to use. Is a huge gap was a thing to use, why is it that spark plug makers don’t set the gap that far open? Why are the surface gap plugs not set at an .080 gap if it is so great and fixes rough running of the motor?Post YOUR testing that validates this.
You can’t? Why not?
Is it because you don’t test anything? Is it because you accept anything written in books and magazines as Gospel truth and never consider there could be ulterior motives?
I have tested it.
Big plug gaps do NOT clean up a rough idle.
Big plug gaps do NOT make more horsepower. In reality, as horsepower goes up the gap needs to tighten up. Why you ask? Well because most guys making horsepower are using higher rpm than 6,000.
As the time to fire each plug gets less as rpm goes up, the spark naturally gets weaker. Oopsie. It’s the nature of the system.
As horsepower goes up, generally so does combustion chamber turbulence. And, smart engine builders find ways to increase combustion chamber efficiency by speeding up the burn rate and increasing turbulence.
Of course, when that happens you increase the probability that the literal hurricane in the combustion chamber (from increased turbulence) will blow the spark right out. Oopsie again.
So how do we deal with the spark getting blown out of that .080 gap? That’s right, WE CLOSE UP THE GAP until the ignition has enough energy to fire the gap. Oopsie.
And what else do we know? We know that opening the plug gap on any decent 7 series ignition box from say .035 to let’s say .060ish will at best show zero increase in power. I test it. It’s the same every time. Going over .035-.040 gap at best shows no hp loss.
Once you are above about 1.7 hp/cid you’ll start losing power with a .045 gap. At a .060 gap it’s about 1.5 hp/cid depending on combustion chamber geometry, quench area, inlet air temperature, fuel stratification and a bunch of **** I don’t understand.
That the facts^^^^^^^^^
Now, what do we know about what happens when we open the plug gaps more than ignition energy can fire? We know, for a fact it plays hell with the cap, rotor and wires. We also know if the gap is wider than the ignition can fire the spark WILL find or make a leak and the spark will go there rather than the plug.
Ooopsie big time.
And what happens when that spark jumps from let’s say the number 5 cylinder to number 7 cylinder?
That is correct. The Ooopsie is now firing the number 7 plug out of time (way too early) and damed if we don’t get detonation on old cylinder 7. Ooopsie. Again.
If we let it go long enough we push the head gasket out. Or if the gasket is tough enough we start abusing the piston and the rings and the ring land starts lifting. And/or you start softening the center of the piston. Eventually that little Ooopsie is now a nice hole in the piston. Yeah big gaps are the ticket to paradise.
Or maybe it starts back siding the piston. That is the non thrust side of the piston is scuffed but the thrust side is not scuffed.
It’s time to stop making horrible claims about plug gaps. I’ve tested it so many times it’s just stupid.
And, the weaker the ignition the sooner the gap needs to get tighter before you incur a misfire.
I run a Accel super coil and it comes with an added ballast along with the stock one for that reason. 50 years and never had an issue.You need somewhere in the neighborhood of a 1.5 to 1.7 resistor. .7 is too low. Especially when it gets hot.
Those are the actual spark plugs that came with the '89 Truck at purchase, running the TBI factory system, plugs burning black.
Put the Mopar/hei converted distributor in along with the 60,000 volt E-Coil, and after a 15 mile round trip they had burned all the carbon off the electrode and insulator turning the insulator white. Pretty cool trick for not having done anything special to it. You can see the previous black carbon at the threaded tip of the spark plug, the whole plug had looked like that with the Throttle Body Injection system and onboard computer controlled distributor which has now been eliminated and now running a 4 bbl carbuetor for fuel supply.
Got rid of all the pollution crap on the engine too, now it runs strong and runs clean.
So yeah all pretty simple, no special engineering or tuning required, bolt on and go > problem free. As everyone knows the 1406 4 bbl is the perfect matched carb for the factory 318 roller engines and 318 roller cam, complimented by the factory higher compression 302 Closed Chamber Heads.
Nice Setup...
Driving a 20 mile loop before pulling a plug is not how it’s done…….Continuing on from Post #169 @Newbomb Turk
Just out of curiosity thought I would pull one spark plug this morning and see how it is burning now in this season after 2 months of running here in 2025.
Looks like they are still burning real nice since last Summer in 2024.
Turned out the 2 idle enrichment screws 1/4 turn (out) yesterday morning before heading out on the 20 mile loop through Palm Bay. Gave it just a little deeper tone out the single exhaust tail pipe at idle, like the way it sounds and handles the idle at the stop lights just fine.
About dialed in running and burning perfect now.
Thanks for viewing...
