Rebuilding my 67 273cui commando engine.
I am using RaceTec HiPo pistons with dome and have a commetic 3-layer metal head gasket with .040" thickness. Everything very good quality.
The fact sheet of the pistons says, that the RaceTec high compression pistons should have a minimum static clearance between piston and cylinder head of no less than .040".
The piston sticks out the block deck exactly .004" at the rim at T.D.C..
With the .040" gasket, that will make a clearance of only .036" (.004" less than minimum).
Does anyone have experience with these clearances? Will this work or will I have to consider to change to a thicker gasket? Any recommendations? Don't wont to work on the pistons.
Checked valve and spark plug clearance as well --> it's ok!
On the pics you see the piston sticking out the block deck (rim). The black spot you see is modelling clay that I first used without and the with the gasket. But this is no reference, since I did not tighten the gasket.
Robert
Robert
