[SOLD] Comp BB Hyd. Roller Cam XR292HR-10
Rating - 0%
0   0   0
Selling the cam out of my 511 stroker motor. Has about 500 miles on it and still looks great. No issues at all, I'm going with a Solid Roller instead. Specs are .549/.541 lift 242/248 duration @0.050. This is the biggest off-the-shelf hyd. roller that Comp offers.
Asking $200+ shipping from Lake Charles, LA 70605
Just bought the same cam for my stroker build! GLWS
tell us about the rest of your build, for comparisons to ours that aren`t done yet.
I went w/ a 292 solid roller, about 10.5-10.8 c.r.,ported alum heads, in hopefully under 3200 lb. barracuda.-----------thanks, bob
It's a 4.375 Bore x 4.25 stroke RB block. 11-1 comp., ProComp CNC heads, Hughes rockers, ported RPM intake, 2" TTI headers and a 850 Mighty Demon. Made 575 HP @ 5700 and 620 ft-lbs @ 3600. It would roast the tires at will. I'm looking to shift my RPM range up with the solid roller to take advantage of some of that head flow!
Sure wish I knew what cam I wanted to go with. I've gotta do more research on how hyd rollers can give a throaty cam great driveability. Out of curiosity, how do you guys think this would go in a 500 stroker w/stealth heads and I'm aiming for 10.5:1?
