[SOLD] Comp Cams Small Block Hydraulic Roller Cam (Custom) & Crane Roller Lifters (New)
74MO
Comp Cams small block custom grind hydraulic roller (20-000-9) Ser # A 6479 2003307 (New)
Duration @ .050 - 230/236 - 340 Int/347 Ex lift - 114 LSA
Valve Lift with 1.5 Rocker Ratio - 510 Int/520 Ex
Valve Lift with 1.6 Rocker Ratio - 544 Int/555 Ex
Crane Hydraulic Roller Lifters - 69532-16
Don't believe it will fit the magnum
All parts are new that have been sitting on shelf - $800 plus shipping from MD
Do you have a picture of the cam card?
I have attached the cam card below as requested…
ITEM #
20-000-9
SERIAL #
A 6479
SPEC CARD #
47011
DURATION @ .050”
230* / 236*
LOBE LIFT
.340” / .347”
LOBE LIFT x ROCKER RATIO = VALVE LIFT
CENTER LINE
114
LOBE SEP
114
INT LOBE ID
3315
EXH LOBE ID
3316
CAM ADVANCE
0
I will be away until Jan 25th. I will respond to any inquiries when I return. Thank you.
