nm9stheham
This is an accurate statement; normal for a good tight 318, with the 318 flat top pistons that are around .075 down in the hole, and maybe thin head gaskets or perhaps some mild head milling. DCR's will be in the 7's with that Comp Cam.135 PSI is fairly low and in the stock range. If I had to hazard a guess, I'd say somewhere around 8-8.5:1 static, but again, there's no way to tell but measure.
Being pleased with the results is good and is the whole point! But it does not quantify anything. I suspect it is not wild tire burner, but that may be good as it won't break loose all over the place with street tires, and probably winds out well once it gets a bit up on the curve.
(The DCR description in post #2 is nonsense. Everyone, please study up!)
