Control Arm Camber Bolts Rusted - Do I have to cut them out?
69cudaownr
Waterloo, Ontario, Canada
Hi guys,
My upper control arm camber bolts are rusted in. The nuts snapped off on both sides when I tried to loosen them. I put lubricant on the remaining bolts, heated them up and smacked with a small mallet. I'm guessing the bolt is rusted to the bushing sleeve and its not going to come out. Am I right in my thinking here?
Do I have to cut the upper control arm off to get those bolts cut off thus ruining the upper control arm? Or is there another trick to it?
Your help is appreciated.
Cut the bolts with a sawzall so you can get the control arms off. Then you can change the bushings and replaced the bolts.
Flame wrench, will be your friend.
I wish I had a torch. I used a sawzall. I got one side done. I tried getting a die grinder in there but I was afraid of hitting the frame mounts. You can see a pile of sawzal blades in the picture.
