Control arm confusion
Garner22
Maroa, IL
Newbie here. I have a 71 Duster that I am converting to BBP front disc. I have purchased a set of 73-75 disc spindles already. I am confused as to what upper control arms I need. Can I use only 73-75 disc upper control arms or are 73-75 10" drum upper control arms the same? I did a search on the topic and came back even more confused :D
I am not 100% sure but check with the auto parts store,see if they both take the same ball joint,if it does you should be ok.I am sure someone will come along that knows for sure.
Your the man that PM'd me about the UCA's that i have listed on eBay?
Anyway, all upper control arms on 73-76 A body's are the same, wether it's a disc brake, or drum brake car.
They are the same thing.
Yes I am the man...and thank you for answering my question. Thats exactly what I needed to know.
