Correct motor mounts brackets for 340 .. Help !!
chargerz
Oklahoma
need pictures of da correct motor mounts brackets for a 71 340 Duster, specially da pass side bracket
Jawesus is all i can say. Pics are everywhere. 273 to 360 are all the same
Try this for reference
With the naked eye, im going with 318 mounts.
The right or passenger 318 mount is the same for a 340. So you are good there.
Its the left or drivers side mount that is different.
You will need to find a left 340 A-body mount.
There is other ways to do it, including using washers, but im not a fan.
I prefer using the correct 340 mount.
I prefer using the correct 340 mount.[/QUOTE
Is da left side mount hard to find !? Where can I look !?
They can be tough to find, and pricey.
If I remember right Rob aka Crackback makes them out of 318 brackets ? Check with him.
Put a search here on the wanted adds.
Ebay, Google, etc.
Seems some have forgot what this site is about.
Exactly.
Happens every now and then… guys take the time, not to help in a constructive way, but to make some smart a$$ comment. So my advice to you is STFU!!
We are all in different stages in the learning and know how process -of the Mopars, in this case.
And don´t for a second believe, just because of this SA comment you made, we think you know everything in the this subject…
Merry Christmas
Stefan
Ebay, Google, etc.
You will probably have to buy a pair if you get them online anywhere, I'd expect to pay $140.00 give or take.
Post an add in the parts wanted section here and Moparts, I'm sure someone has one they'd part with. Good luck in your search.
You mean posting duplicate threads?
And ?
You are a technical editor ?
Here is a member asking for some relatively simple technical advice, in which you have no answer for. Obviously, there is a language/grammar barrier here, so why harass him ?
You either have to be part of the solution, or you're going to be part of the problem.
