1970 Dart 318, new stock wiring, standard dash (not Rallye) with gauge. Just replaced the entire cooling system. Replaced Temp sending unit with OER 2426458 from Summit. Gauge hardly registers when temp gun says engine is at 180degrees. Gauge does react but just a bit over the line above "C", but it does move. Everything seems to be functioning properly in the cooling system but the temp gauge. In looking for a replacement for the OER unit I see ECH TS6178 from NAPA and Standard TS-17 elsewhere. What is the current wisdom on the best unit to use?
