[WANTED] crane gold rockers needed
dust-u
I am looking for three replacement crane gold rockers for my 340 duster. I recently came across a used set and three I just don't want to risk running. Looks like getting replacements from crane might be an issue,I should have done my research. can anyone help out a fellow member?I relly don't need any more paperweights..
1.5's? I suppose any like AL rocker would work, but it would probably be blue...(MP. proform, chink)
Crane rockers do not last very long. I never had any luck with them and they were the cause of the destruction of two of my motors. They just do not hold up to large roller cams that require high spring pressure. Norse or comp ductle iron. or T&D is what worked and held up for me. Just some info you may consider. No. 1 Rule I live by is no soft aluminum parts in the valve train.
Have you contacted crane?....I
Single rocker arms were still available on summit a few months ago
yes, I called summit and had no luck(chat) I have emailed and am awaiting an answer
Just a few months ago I bought a couple of replacement crane w2 intake rockers and all the standard and w2 gold rockers were available from Summit....actually bought them from Jegs since they were cheaper.
  • The part CRN-69750-1 is being discontinued and only has 1 available for purchase. The quantity you requested for CRN-69750-1 has been adjusted accordingly.
