Crane roller rockers
D-mailman
Lexington,ky.
Crane roller rockers for small block mopar std. LA heads. Will these rockers stand up to roller springs with 220 lbs closed and 520 lbs open pressures ? please advise and thanks.
Im using crane gold roller rockers with 220 at the seat no issues I think thats what Indy cylinder heads used
Yeah. You're at the upper side of the window, but they'll be fine.
coil bind is what breaks rocker arms,not rpm.....I'm running k-motions with 640 open pressure on eddy heads with a "little" massaging on the spring seat
