the stick shift dakotas and jeeps,,,not sure about the ram,,, now use a roller bearing some are a bushing, that goes in the torque converter register hole,.
that is the first step you see in the crank end,, that is where the large end(button) of the torgue converter goes when bolting the converter to the flex plate when useing an automatic...
you can get them at mopar, napa, and probably most auto parts stores,,,if the hole in the crank is not cut deep enough,you simply bolt it all together see how much of a gap you have between the tranny and the bell housing, and trim off that much on the very end of the manual trans imput shaft.
