thechamp
My 16 year old sons 71’ Demon 340 new build. Finally after 3 years it was time to fire her up tonight and it turned into a parts Change out pretty quick. Everything on the car is new, except the harness. It will crank but not start, it did fire and run for about 3 seconds one time. It had intermittent spark, now has no spark. While trouble shooting I did notice with the coil white off the distributor.. when you turn the key to the on position it will spark one time then will not spark while cranking. Tried 2 coils, 2 ignition boxes, 2 voltage regulators,2 distributors, with no progress. I have voltage to the coil, voltage on both sides of the ballast resistor.
I do not have the gages in the car and have the wires to the alternator gauge jumped together. Please help me out to trouble shoot the next thing. If your suggestion is the ignition the switch, let me know a way to temporarily bypass or check that before pulling the colum again.. thanks everyone in advance!
