Crate engine intake manifold
rtee007
Deplorable Texan
Baytown, Texas
question, does the 360 MP crate motor accept a standard LA intake?
P5153475 360 Magnum Crate Engine — 390 Horsepower, 420 ft.-lbs. Torque Magnum Block Thermocycled .020" Overbore
Based on the Info provided..................
If it is a Magnum crate engine...NO it will not
If it is a LA crate engine...Yes it will...
Ok...If it is a Magnum Engine from the Factory...it will have the Magnum bolt pattern...
Did they make a 360 crate based on an LA? Crosswind style intake will fit both but your quality may vary based on previous posts but Magnum mounting seems good.
That is a Magnum engine as clearly seen by the Magnum intake manifold on top.
You can not use an LA intake.
Crap! Posted by accident...
Since your create engine already has an intake, why is it you want to bolt on an LA intake?
not totally true.i would run it and see how it does,if it has bad manners you could use a rpm air gap
