You can remove it, but I would try to apply a lot of WD40 into the stabilizer bushings and see if the squeak goes away. It looks dry in the photo. I had that issue on my 69 and it worked for me. The same with my control arm bushings.I know I could do a full-on front end rebuild and this would probably go away, but I'd feel like an idiot if I didn't figure out what has failed first.
Certainly worth a try to spray lube things one by one just to sleuth out what is making the noise.You can remove it, but I would try to apply a lot of WD40 into the stabilizer bushings and see if the squeak goes away. It looks dry in the photo. I had that issue on my 69 and it worked for me. The same with my control arm bushings.
"rare parts" makes them. O'reilly & napa "carry" them, and that means special order. but i'd hazard a guess that they're made in the same place the moog's are and just reboxed.Those tubular UCAs are cool, but a bit pricey. Maybe some day.
Does anybody else make offset UCA bushings? I’ve heard great things about the Moog K7103 for years - nobody has copied it or improved on it?
I'll never understand why people just throw diagnostics to the wind. Makes absolutely zero sense. Good luck with it.
Diagnostic is not a double effort. It is part of the job. Let's say for example, instead of the pop originating from any of the front suspension or steering parts that you have a crack somewhere in the attaching part of a frame rail or control arm ear. Every time the wheel is turned, it flexes that area and pops. I think that's unlikely, but I'm just throwing a "what if" out there. After doing all this work "what if" something like that is the case? You'll still have the issue. Without diagnostics, you have not 100% verified the problem. Have fun. I'm out.Not really what is happening here. This car is a little sloppy and needs a front end rebuild regardless -- the noise is just the catalyst to get me to do it. I will certainly find the diagnosis along the way, but why double my efforts?
Just to add to your comment Rusty, I once had a crack at the upper control arm bracket, attached to the frame that needed welding back on. Diagnose before fixing.Diagnostic is not a double effort. It is part of the job. Let's say for example, instead of the pop originating from any of the front suspension or steering parts that you have a crack somewhere in the attaching part of a frame rail or control arm ear. Every time the wheel is turned, it flexes that area and pops. I think that's unlikely, but I'm just throwing a "what if" out there. After doing all this work "what if" something like that is the case? You'll still have the issue. Without diagnostics, you have not 100% verified the problem. Have fun. I'm out.
VHT rollbar & chassis black lays down super nice and dries fast. same with duplicolor engine enamel. i've tried the "raptor" chassis paint, and it's good: meets all the criteria: self priming, heat/uv, abrasion, tough, etc, etc. but it sprays *** and the coverage sucks per can.Thanks in advance.
- What's a good rattle-can option for priming and painting suspension parts (LCA, UCA)?
- Do people use Loctite red or blue when assembling all this stuff? Or is it fine to just torque everything to FSM spec?
Are the sway bar mounts for the LCA 67-72 style? if so where did you get them?Following a full front-end rebuild
I bought the sway bar mounts from Peter Bergman. Although they are identified for 67-72 a-body mopar, they wouldn't have worked as sold, so I cut them up a bit before welding them on. I was super happy with the result. See here for the story.Are the sway bar mounts for the LCA 67-72 style? if so where did you get them?
Hmmm...or I misremembered what I saw before. I doubt it would be plug-and-play for any particular LCA, but it could certainly work for any year LCA with minor modifications. I couldn't have had someone bend super-thick metal like that for the price, and the only "mods" I did were some quick slices with a cutting wheel, so I consider it a good deal.looks like they changed their description
I'm replacing the shock tower / upper control arm brackets on a 76 Dart. I have the angle off on the Classic Industries replacement I bought. Can anyone tell me the inches between the bolt hole and the bottom of the frame in the picture attached. I used your frame pic for reference.It's been quite a while but I just wanted to post a resolution to this. The noise in the original video was coming from the ball joint in the idler arm. Once I got it out I could tell it was toast, with massive friction and uneven movement.
Following a full front-end rebuild, the car is back in action and driving really nicely. Most of the parts came from Kanter, except for the Moog Problem Solvers, Moog 2-piece strut rod bushings, and Proforged LCA bushings. Shocks are Sachs (available on Rock Auto). Not a lot of rust on this car, which made the job pretty smooth. The alignment guy said he got the Caster at just about 3 degrees and it's amazing how much highway driving improved from that.
I painted the parts with Raptor chassis paint, which seems to stick really well.
I didnt take a ton of pictures during the process, but here are the few I did.....
