Creative Fix for Spinning Frame Nut During Steering Gear Install
Cuda_Jim
New Member
Orlando, FL
Hey all,
Long-time lurker here—finally wanted to contribute something. While doing a front disc brake conversion and suspension rebuild on my ’70 340 Cuda, I ran into a headache with the steering gear install.
At the last minute, I decided to rebuild the gear and coupler—figured I might as well finish the job right. When I pulled the steering gear, I noticed the lower tack-welded frame nut was spinning. Not ideal, but manageable with a wrench.
Then came the real problem: while reinstalling, the upper driver’s side nut broke loose and dropped inside the K-frame. As many of you know, that nut is nearly impossible to access—especially with the gear in place.
I started looking around forums, and the common fix was to drop the K-frame and cut an access hole to re-weld the nut. After the car had been down for a couple of months and was so close to being done, that was the last thing I wanted to do. So... I cracked a beer (because all great redneck engineering starts with one) and came up with a workaround that actually worked great.
Here’s my workaround:
  • Cut the closed end off a cheap 13/16" wrench.
  • Applied JB Weld to the nut and the inside of the wrench head, and let it set up.
  • With some careful finger work, I was just barely able to push the nut/wrench assembly into position and start a bolt to hold it in place.
  • To hold it there while finishing the install, I shot expanding foam into the cavity.
  • Once cured, I removed the bolt—the nut and wrench stayed perfectly in place.
  • Reinstalled the steering gear, and the wrench stub locked itself against the K-frame while I torqued everything down.
I know it’s not a “proper” welded fix, but it worked perfectly, was quick, and didn’t require tearing everything apart. Maybe I’ll address it the traditional way when I eventually pull the engine. For now, I’m back on the road—and that’s what matters.
Hope this helps someone in the same boat!
I like it, but ..
If the foam is not closed cell it can get wet and hold moisture inside the k frame.
Just something to watch for.
But I like the redneck engineering!
I like it, but ..
That thought did cross my mind, and I did verify that it is closed cell, but honestly with all the years of greasy grime that is built up inside area I don’t think it could ever rust.
