[WANTED] Cuda floor piece
I think I have that piece but I'm not sure which piece you're talking about? Is it the large vertical sheet metal piece that covers the whole side of the storage area behind the rear seat?? The same piece of sheet metal also covers the rear wheel wells. I have that if that's what you need??
treblig
treblig
No it's the 4" or so tall piece that runs across the trunk floor to support the package area floor .
If this is the piece you're looking for it might be a problem?? The metal floor in the package area behind the rear seat on a fastback is one continuous piece which includes the vertical 4 inch section. Unless I'm looking at the wrong piece?? The one in this pic has some surface rust on one side but it's solid and will clean up real nice (no rust through or weak spots).
Treblig
Treblig
The part he needs is spot welded to the trunk floor pan right in front of the spare tire well
Thanks Treblig , Barracudakid got to me by Pm first so I'm probably going to buy his piece after he emails me a pic or two , your certainly next if something goes sideways and I certainly appreciate everyones quick response .
PS yes it was the piece described by cudascott it's actually what the other end of the piece Trebig showed mounts to .
