racerdude5
Does anyone have a custom, one of a kind front suspension system or k member? Has anyone made a reinforced pivot for factory lower control arms?
You have rms alterKation, Hemi Danny K frame setup, hotchiks TVS setup. Not so much as a one off because anybody can buy one of those. That said if you want to use the same parts a modern/new car uses you'll need to use the suspension setup from the roadster shop.
So there's like a support with a bearing that slides over the torsion bar socket and bolts to the k-member
