custom door panels with armrests & pockets
Martythetrimmer
Canberra Australia
by now some of you will know I don't do stock with my trims.....I'm not a fan of the painted door tops on A bodies so I made full lenght door panels
I started by tapeing up the door tops to mould a fibreglass cap
I then bonded it to the panel while inplace on the door
I then started on the armrests and door pockets.....I used 1/2" MDF for the frames
I again used Urethane foam for the sections that are to be shaped
that's about all I have time to post right now so....to be continued!!
Perfect timing... I just started working on the same thing and could use some " how to" guidance since I've never tried this before..... so I'll be following along closely.
part 2....
the foam is easy to cut and sand with 80 grit
once fibreglassed I did a test fit
vinyl work done, pockets need to be linned with felt and the fabric insert has to be fitted
the three main stages of the project
not finished but gives an idea where it's going....
Time well spent :cheers: These look so darn nizze Martythetrimmer :glasses7: great job sir :coffee2:
