[SOLD] Custom engraved sill plates (1 pair with screws) 2 door only
66Dvert
Working on my custom car parts again!
Webster , florida
Custom engraved sill plates for the 63-66 model year cars 2 door only and for the models of Valiant , Dodge Dart 270, Dodge Dart (GT OR
dodge emblem) ,Barracuda (in script or block text), DODGE or PLYMOUTH names only fit like originals and are a bit thicker on the metal thickness, comes with mounting screws also custom names can be done by messaging me with an extra charge. 99.00 plus shipping
Do they fit only the 2 door Dodge/Plymouth hardtops or will they fit the 2 door sedan varieties?
All the standard 2 doors, (hardtop convertible and post cars that I have tested them on. So I think your altered 2 door in your avatar still has the same length door opening as the hardtops and convertibles do , (Sill plates at 38.25"ish or so) I do have the measurements for the 4-door cars though and might make a few of those also once I can design the hole pattern and fold dimensions since I do have a moredoor to test fit it to so Waggons will likely get done too! I put an smoothing/strengthening edge ridge similar to the originals on the newest ones to make the ends a bit stronger and will retrofit the others to match double check your overall hole to hole I'm using 34,165 ish on my drilling setup and they fit perfectly on the Hardtop and convertibles I have test fit them on.
