My question is when you have a set of heads fulley ported and polished should have 4 to 5 threads showing inside the combustion chamber
you probably have the wrong plug.When I got my heads back from the porter I was looking at the combustion chamber. I screwed in a spark plug and there was 4 to 5 threads showing in side the chamber
B blockLA or B? you want the spark kernal in the cylinder, not the plug threads.
I just found a pairagraf in Max Performance Mopar that said this was done by bad machining
No they remove the hump that covers the spark plug inside the combustion chamber
