I forgot to mention the low first gear. lol
That Mai be one of the newer styles that you can adjust the amount of mechanical advance with a screw.More Information for SKP SKDICH14
Maybe I should buy this and start working with it. Sure is cheap enough...
Any Mopar vacuum advance that has the hex behind the nipple has the adjustable vacuum can.That Mai be one of the newer styles that you can adjust the amount of mechanical advance with a screw.
He said mechanical advanceAny Mopar vacuum advance that has the hex behind the nipple has the adjustable vacuum can.
Yeah he did, didn't he? lolHe said mechanical advance
I would like a 100 mph. I hope you are right!Good point. Put me down for 100 mph.
Ok so let's say it's a 74 GTX.On a side note, not much has been mentioned about the MPH. It's hard for me to put a MPH on this thing. I can't see any way it will out MPH a factory '68 GTX. About the same weight, cutting more wind, and less HP ??
Good number. I guess I was so focused on ET, and how it would get that ET that I never really considered what my expectations were for MPH. I may be in for a surprise, but I can't see it breaking 100I’m gonna give it a solid 94mph. If we’re doing those guesses now
I 100% agree. I'm counting on a good ET because I have the truck working (at least with the 5.9).ET is just gonna tell you if it all works together. MPH will tell you if it’s making power or not. Don’t ask how I know.
Tell us more ....I wonder how it compares to my big block half ton.
That's my friend and he's doing my transmission. He's been racing that truck since the early 80s. It was the record holder in his class in Stock Eliminator in the mid 90's
small block?That's my friend and he's doing my transmission. He's been racing that truck since the early 80s. It was the record holder in his class in Stock Eliminator in the mid 90's
Yes. Stocker it had to be. Didn't make BB's in those years.small block?
So is that who yer goin after?That's my friend and he's doing my transmission. He's been racing that truck since the early 80s. It was the record holder in his class in Stock Eliminator in the mid 90's
naw, last year he was running a next to stock 360 and at 4k lbs, I was faster than him. He is bracket racing now, not stocker stuffSo is that who yer goin after?
