JohnnyJet
Ok Ive seen the swap, what does it entail. I have a 4 speed now linked to a 360
I was going to put one in my 38 plymouth coupe. I had a 440 4spd mocked upin there. The trans tunel and bellhousing area will need to be bigger. The 5spd I used was out of a 2000 5.2 5spd Dakota. The trans and bell is a lot larger because of all the ribs on the trans and bell. To use this trans you will need to redo the tunel in a stock A body.
nothing that comes factory anything will likely hold up unless were talking about a viper spec t56 (6 speed...in my opinion way too much and useless since realy why do you need 2 overdrives?)
because at 70mph it's only turning 1600rpm with 3.72 gears
ok thats out then looks like i need to find an alternative as i can hack up my car. keisler or passon? I guess Ill look into them. Thanks guys. I heard Mcloud is coming out with a tranny too so maybe Ill wait
Those Dakota trannies are just that, truck transmissions. Useless in any high performance application as far as I'm concerned but for just a MPG cruiser, well maybe it's OK but I still don't like it.
Well.. If you run the standing mile it can be very helpful. It lets you run really low rear gears.
Why do you say that?
If fabrication is something you're OK with. You might look into an 5-speed R154 out of a 87-92 turbo supra. Its got better gear ratios and stronger than the dakota transmission, but will bolt to a dakota bellhousing. There are a couple of threads posted on hear and a couple of the other boards about the swap.
