PistolGrip
:violent1:I have a '66 Barracuda. The driver's side door was getting a little tired (sagging) about 10 years ago. I installed new hinge pins & everything was fine. A couple of times over the past few years the striker thingy that the wheel on the door is supposed to go into has moved a little & the door won't close - I get that awful CLUNK! sound. I've tried just about every adjustment combination I can come up with, but I'm not having much luck. The passenger door still closes perfectly & I've tried to copy that position, but........
There is no adjustment on the door & the wheel works fine.
All of the parts look good & the door is solid on the hinges. What's the trick?
