jos51700
Green Bearing thread connoisseur
I'm trying to find out, is the key-way on a small-block vibration damper clocked to any certain point on the crank? I know that they're all clocked the same (so the timing marks work their magic), but is the key clocked to any specific feature, like #1TDC or something?
Are the bolt holes for the pulleys always in the same place on the damper, relative to the keyway?
Thanks
John
Thanks
John
