mopowers
Anyone have a photo of a distorted axle tube from a round u-bolt that was properly torqued?
A man's gotta do what a man's gotta do!In a wrecking yard I used a 6 foot fence post as a cheater bar.
Hopefully coming off and not going on. LOLIn a wrecking yard I used a 6 foot fence post as a cheater bar.
Be sure you get the type with the knurled flattened portion in the middle of the UI don't even think about it. melt em off. My machine shop makes em
Some of the post in this thread say the flat thang aint necessary. I enjoy the idea that it is important but some disagree.Be sure you get the type with the knurled flattened portion in the middle of the U
Without that you will crush the housing tube. Also the torque is 45 lbs not 100, not that feels about right.
Look in the FSM to verify the number but I'm 98% sure.
That's just not true. All I've ever used are round u-bolts and I've never crushed anything. Crushing the axle tubes comes from over torquing the nuts and nothing more. You're correct on the torque spec. It's only 45LBFT.Be sure you get the type with the knurled flattened portion in the middle of the U
I have to wonder why ma-mopar went through the effort to do the flattening and the cross x if is not needed.That's just not true. All I've ever used are round u-bolts and I've never crushed anything. Crushing the axle tubes comes from over torquing the nuts and nothing more. You're correct on the torque spec. It's only 45LBFT.
I'm tellin all yall...and for the last time cause I'm growing tired of repeating it for folks that obviously think I'm lying, but they used both styles through the years.I have to wonder why ma-mopar went through the effort to do the flattening and the cross x if it was not needed.
Do you think it maybe a performance application ? I have run into both too but have not paid attention to the application.I'm tellin all yall...and for the last time cause I'm growing tired of repeating it for folks that obviously think I'm lying, but they used both styles through the years.
Yeah, same guy with the photo of the exploded ball & trunion driveshaft joint.Anyone have a photo of a distorted axle tube from a round u-bolt that was properly torqued?
I've had a few original cars with both, the reason for either not obvious.they used both styles through the years.
all u bolts are mild steelEvery day...
I reused the ones on my truck.
wanna buy a bridge? lol, just kiddingEvery day...
The more likely scenario was they were rat a tatted to hell and back with an impact gun.Yeah, same guy with the photo of the exploded ball & trunion driveshaft joint.
That right there is it in a nutshell. However, "whichever" u-bolts you use, the need to be torqued to the factory spec of 45LBFT. Here's why. If they are over torqued, they will pinch the leafs in a bind and they will not compress and rebound properly. It can render the rear suspension pretty much useless.most people way over torque them.
You forget about point load. Round u bolts exert all there clamping force over a very small area meaning the psi is greater. The flattened u bolts spread the load over a many times greater area meaning for the same force the psi is considerably lower.all u bolts are mild steel
distorted housings are an installer fail
the flat oem ones are weaker than solid bar
different torque specs for different products
don't torq a round ubolt to the factory specs, use the ubolt spec and never crush a tube
trailer ubolts of proper load rating are fine replacements
my old trash truck (5ton+) had the same bolts off and on so many times to change the overloadsI reused the ones on my truck.
Factory spec is 45LBFT. FORTY FIVE FOOT POUNDS. You ain't gonna distort a thing at that torque.the flat is thinner, and has more stretch/give
torquing a round to the same value WILL distort the axle
the u bolt only needs a bit of stretch
as I said, never torque a round to the factory/flat spec
the distortion could be not from the ubolt tighteningYou forget about point load. Round u bolts exert all there clamping force over a very small area meaning the psi is greater. The flattened u bolts spread the load over a many times greater area meaning for the same force the psi is considerably lower.
I have a housing where you can see the shape of a round u bolt on the inside and outside of the housing. I'm sure it was over torqued too but if it had had the flattened section I doubt for the same torque it would have done that.
