Dart column parts
dmkberger
Member
Lake Havasu City, Arizona
I have a 1972 Dart column in need of some bearings or bushings, I am not able to find a picture of what should be in there in the first place, so I am not sure of what exactly is missing, anyone know of a site with a blown up diagram of this column?
The shaft is very loose at the coupler end....nice big tube with the little shaft rattling around inside it.
The shifter tube seems to be missing some parts at the bottom end as well.
Can anyone help with a picture or have any idea what should be there?
I don't have any pics, but if you find out what your missing let me know. I have a bunch of spare columns for parts.
I can't remember everything so tell me... does this shaft have a collar w/allen set screw at the bottom ? See I dont recall what year they changed.
Then again regardless of which it is I should have everything needed to fix it here.
There's sposed to be an insert in the tube with a 1/4 hex head screw through the sloted hole in side holding it in place that serves as a bearing housing. Then a spring that maintains the bearing load (glorified bicycle bearing with tapered race). Bearing replace kit wont include that housing :(
Any of this helping ? Wanna just send the column and I'll fix it for you ?
