Lower steering column bearing
moparfanatic56
0quawka, il
Does anybody have a source or part number for a roller bearing for the lower steering column tube. I have the nylon one further up in the tube but would like one at the end of the tube, still have a lot of side to side play. Also can the pin that holds the shoes in place inside the coupler be pressed out and pressed back in so I don't have to tear the column all apart. Thanks
There are several bearings depending on application and year
Auto on column
Floor shift
Manual on column
