Dodge72
Odd one out
Of course, when the weather is as sunny as can be and 65 degrees, The Dart gets cranky. Started yesterday when it began to diesel real bad. Worse bout lasted about 5 seconds and actually sounded like a whole diesel engine under the hood! Got under the hood and saw my fuel boiling. Moved the fuel line off the valve cover. I turned down the idle too, as low as it can go. Seemed to help, but it's still giving me a stumble when shut off and sometimes diesel for a second. After diving it all day, I parked it for a. hour before work. Came back, and it cranked forever! Sounded like it was starting, but failed to idle. Finally got it running, but now idle is SUPER rough ( probably turned the idle down too far). Took another car to work.
So here's the thing...
Timing at 5 BTDC.
Only diesels when it's fully warmed up, not when sitting for an hour or more.
Never dieseled in winter.
Only this week switched to 87 octane. Before I was using 89 and no problems.
Going to check my spark plugs.
Have a 180 thermostat.
Heard carbon deposits could affect this. Any way to test for that?
Maybe it's overheating? I don't have a working gauge.
Again, ONLY began yesterday when the weather got warm and my octane level switched. Anything helps, will have more info tomorrow!
Timing at 5 BTDC.
