604
OK you can stop lecturing. WE don't know what you have or have not done. But timing COULD VERY WELL BE the issue.
So I have a question. With all the rodeo's behind you, did you check that the dist advance IS NOT STUCK? Is the timing actually advancing up to say, 35-40* total?
One I am not lecturing,
But seem to be the one getting lectured for some reason. And yes the advance is working properly. I checked that one of the first things. Every time I check or set the timing on something I check that. But that is a very valid point. I have had that stick before on a 454 with an HEI. Boy did it run like you know what!!
I even bypassed the delay pot on the fire wall. I read allot about doing that. Seemed to run worlds better after that.
