Happy place!
If you have the 73+ spindles and calipers, you could buy the 11.75” caliper brackets and rotors. Factory parts but an upgrade over standard 73+ brakes.Submerged my manifolds in 7 gallons of vinegar with 3 gallons of water. Going to get them all cleaned up.
Picked up some hose to connect install the coolant overflow tank today, that should be a quick and painless install.
Looking at rear axles for the 8 3/4, and most likely going to do a disc brake swap on it. Reason for this is it's the same price as drums so I might as well do the discs.
I'm still undecided on what to do up front. On one hand I have the 73+ brake assembly with all the parts to do the swap less the brake pads, and possibly new rotors? On the other hand, all that stuff is old and by the time I replace some parts, bushings, buy brake lines, and other little things I'm almost at the price of a new front disc brake kit.
Ooh also found these- wheel seals is what I find when I search the part #
So decisions decisions.
Do you have the right radiator cap for the recovery system? They are different.
Sounds like your leaning towards buying new assembly. Cool ! If so , you can sell the 73+ setup and re-coup some cash, lots of guys want them . How's mom and Rose doing ??
You'll find out... if the system doesn't work like it's supposed to.I don't know? I have a coolant overflow line next to my cap right now .
SSBC discs all-around. No problems at all. I do think they went belly-up. The company had been around forever. Summit does not list them anymore. Anyways, as far as I now their pads and calipers are OEM parts. So those parts will be available forever. The discs may be OEM also. I'm sure someone will come along to fill their spot.Touche! I don't think anything on my car works how it is supposed to work haha. I've actually had a slight bog off the line with my car lately, but only happens right after I start driving it until it fully warms up.
I'll order a new cap with the new radiatorhopefully ccase gets radiators back in stock soon!
Do you still have ssbc fronts, from previous posts you really liked them? I thought I read somewhere that they went bankrupt and I haven't seen anyone selling the fronts anymore?
Is there a way to test if my calipers work or need rebuilt? Or can I not do that until I have it all installed?
I bought a complete front end rebuild kit from PST when I rebuild my front end. I believe I got all my brake stuff, including hoses, from rock auto.
As far as your caliper brackets go, the ones you currently have are for the smaller rotors.
These are the brackets you need, these are front Dr. Diff so you could either buy them on eBay or straight from Cass if you’re buying other stuff from him.
Mopar Caliper Brackets fit 11.75" rotors on '73 up DISC knuckles A/B/E body NEW | eBay
Yes sir. I know that from experience....Awesome, that's good to know! I need to buy front end rebuild parts for a 73+ year Mopar correct?
LolHeck yea, the M body axle will be too wide to use???? but the brake and wheels will work well.
Check the book, I can be mistook!Yea I think you're right, I was mistaken and only reading a diplomat swap, my apologies!
